Removes dynamic entries in the IP ARP table.
| ip_addr | Specifies an IP address. |
| vlan_name | Specifies a VLAN name. |
| vr_name | Specifies a Virtual Router (VR) or Virtual Router Forwarding instance (VRF) name. |
| refresh | Refreshes the ARP cache and deletes the inactive entries. |
If you do not specify a VR or VRF, the current VR context is used.
Permanent IP ARP entries are not affected.
This command is specific to a single VR or VRF, and it applies to the current VR context if you do not specify a VR or VRF.
Based on the attributes you specify, the refresh attribute refreshes and deletes the corresponding ARP entries as follows:
The following example removes a dynamically created entry from the IP ARP table:
clear iparp 10.1.1.5
The following example refreshes the ARP entry by sending an ARP request for the IP address 10.1.1.5. If the ARP response is received, the dynamic entry is retained; otherwise, the dynamic entry is removed from the IP ARP table if the ARP response is not received.
clear iparp 10.1.1.5 refresh
The refresh keyword was added in ExtremeXOS 15.7.1.
